air shockreplaced
Any ideas of what it may be..... they didnt tighten a ball joint or something or over tightened something while putting it all together? They also replaced the lower ball joints and bushings while doing the shocks. Any help, or educated guesses would be so appreciated! Its been a process, thats for sure. But, not spending the 3-4 thousand $ at the dealer.
What do you mean by that? Ball joints to me are a straight r n r. Could you possibly go deeper into this because I replaced the drivers side lower control arm with the bottom ball joint to replace the poor ball joint and banging noises last year and the noise never really went away. I've been under there with crow bars and can not seem to locate the problem (however recently the passenger side ball joint is showing some wear)
Regards
Tower
