Intercooler Pump & Misfire
I've had a random misfire problem on cylinders 7, 8 & 9 for quite some time now.
After reset, the CEL will come on when the engine is up to temperature and you give it more than about 1/2 throttle.
I've replaced:
Spark plugs & red silicone boots
Ignition Coil Pack
Fuel pump & filter
I've Checked:
For vacuum leaks
Ignition Module
O2 Sensors
Fuel pressure
Recently I found the intercooler pump is getting 12 volts, but not running.
Does anyone know if a failed intercooler pump causes misfires?
Thanks,
Drew
