how many miles do you have on your s class?
2000 s500
mileage:203,878 curious as to what y'all have and how many miles ya think they will go..i plan on pushing my until the engine blows…gonna try for the 500,000 mark..i change the oil every 3,000 with mobil 1 and take dam great care of it…previous owner was a mechanic and took excellent care of it…the old saying "ya get what ya pay for"these were the top of the line cars back in 2000 out of all high end luxury cars…they are well built. |
2004 S430
Mileage: 198,000 I've only had the car since October 2013, It is in pristine condition and I plan on keeping it until the wheels fall off. I'm loving it! |
Originally Posted by ttaylor993
(Post 6044746)
2004 S430
2000 s430 203000 miles
Had the transmission fail at 190k but its a great car and still drives like a new car |
Originally Posted by tusabes
(Post 6044769)
I got my tranny for $500 from a mbworld member parting out a car with 80k miles On it, had it installed for $300
A rebuild would have cost $2500 at an independent mechanic , or $8000 from the dealer . You have to know how to source cheap parts for these cars . With 200000 miles it makes no sense to put in a brand new 0 mile tranny |
2003 S500 just 115,000 miles. However, the other day I had this cracking noise (like someone squeezing one of those plastic water bottles inside my driver's side door). I'm almost certain it is the actuator because if I use the soft close on that door I can hear the air seeping. I'm told that actuator is a bear to replace but I'll tackle it sometime next week.
My 600 has 89,xxx miles currently. I'll keep it at until either A) I find a W221 600 [easier said than done] or B) I have to spend another $20k on the ABC system.
Originally Posted by ibeforreal
(Post 6044996)
At 135k. After restoration of eletronics, airmatic, and countless other items when i bought it with 116k, its now purring along just fine now.
2006 S430- 22k Miles
Thanks Tusabes I have already pulled the fuse. Unlike some other folks on here who have stated that they would pull the fuse and then put it back in, mine is out until the actuator is fixed.
'02 S500. Just turned 91,000. I'm the second owner. Looked up the CarFax on it and was serviced on schedule by original owner. So far have replaced rear struts and battery. It sits for weeks at a time, then highway driven for a few days, then sits again. Will be quite awhile before it hits 100K.
My 2004 S320 CDI has 165k miles or 260tkms.Pretty faultless except some airmatic woes and minor electric troubles.Though i can feel the transmission is on its way - slight slipping and fluid turned dark in only 20k miles.
2005 S430 has 220K. No major issues but regular maintenance and still runs, shifts and looks like new. Only "major" issue I have had in the past year is a water pump, but was not that expensive. Amazing how good the Mercedes Interior hold up unlike other manufacturers.
Originally Posted by Busman8
(Post 6045983)
2004 S600 V12TT with 157,000 miles and no warranty.
Tyres, ABC hose, tyres, coil pack, tyres, brakes, tyres. Nick |
1 Attachment(s)
Had this car since almost new back then just hit 100K miles
nice!havn't had mine since new,but it's been in the family..my dad paid over $100,000 for mine new…sucks that they go down in value so much:(it's only cause they cost so much to maintain:(mine drives and runs like it's brand new still:)best car ever built!
Just picked up an 01' with 88k, hopefully I get another 100k out of her.
Just bought S500 4matic with 114k miles have 122k miles now. PO had dealer service every 7500 miles, used dealer I purchased from replaced oil (tranny & engine) serp belt , tires and headlight bulbs. Looking for 500,000 miles daily driver and loving it! (about 120 miles roundtrip daily).
2005 S500, 98000 miles. Second owner.
My 2006 currently has 237K and runs well. No major issues except for the parts that normally wear out. I plan on running it till the wheels fall off. I drive 500-600 miles per week.
You gots to pay to play playa!
2006 S65 AMG with only 58k miles on it. 60k mile service completed with 24 new spark plugs, 2 new updated coil packs, new radiator, new thermostat and housing, new hoses, Coolant system flushed, replaced Turbo Intercooler charge air auxilary water pump with the updated one. ABC system flushed during oil, oil filter, air and cabin filter and fuel filter change and transmission service. Both ABC filters replaced. Motor Mounts replaced when replacing the o-rings and gaskets on the turbo hard coolant lines. Total parts cost $ 4,300, and total labor cost $ 3,325. (Turbo hard coolant lines o-ring and gasket replacement alone was a 22 hour job, which my Indy charged me only 12 hours and the cost of labor was $ 1,530, o-ring and gaskets cost $ 8.) Spent $ 7,625, :eek: however, the feeling of flying around in this 747 like Jet after all the work is done is Priceless! Cheers!~:zoom:
Originally Posted by gregwang168
(Post 6051580)
