W220 S-Class Aluminum Shifter Lever Repair Kit
Old Jul 24, 2014 | 01:37 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Only $103.50*
An excellent replacement part for your W220 S-Class, the URO aluminum shift lever upgrade eliminates the poorly designed plastic part supplied by Mercedes-Benz.
The URO kit it contains each part required for a complete shift lever repair,
including the rivets and shims necessary to rebuild the shifter assembly.
Note: Two styles of shift levers are differentiated by the width of the hinge pivot base (5mm or 11mm). The part is not defined by a specific year or chassis, so inspection of the existing plastic lever within the shifter may be necessary.
*Price subject to change.
