2004 S600 Key not recognized
I have a Catch 22 situation with my local MB dealer. My 2004 S600 with a Lorinser body kit was parked thru' the winter and the battery died down. Recharged the battery but then got the message "key not recognized". Checked key fob batteries and they are fine. The airmatic suspension has dropped and the body is sitting on the wheels. When I called my local MB dealer, he wants me to get the car towed in before they can reset the key. MB Roadside assistance tow companies will not tocuh the car since the vehicle is resting on the wheels and if they drag it it may damage the fenders. They asked if there is an airmatic override which would ligt the vehicle sufficinetly for them to get in on to a flatbed. The MB dealer says NO. The towers will not tow it and MB will not do anything unless it is at their service center. So my car is dead in my garage and stuck there.
SEEMS STRANGE THAT SUCH AN EXPENSIVE AND TOP OF THE LINE CAR HAS NO SOLUTION TO THIS PROBLEM.
Thanks a ton for any suggestion that will get this problem solved !!
It has abc which is a hydraulic suspension , not an air suspension
Upon starting the car it should come up to proper height.
Have mb roadside come out to the vehicle, to try to get it started in its current location .
If it must be towed, There is a towing product called GoJacks that slip under each wheel and lift the car up. If the towing company puts the car on go jacks then they can safely roll it onto a flatbed. Your wheels will not need to roll, the gojacks act as dollies and have their own little wheels. Then they remove the GoJacks Once its on the flatbed. Most good tow companies will have go jacks , but you need to be sure they bring them
Auto reposessors use these to move cars locked in park without damage
I am in Calgary, Canada and MB roadside assistance do not come to get the vehicle. They sub-contract to local towing companies.
And the local MB dealer will not send a technician out to the vehicle with a portable diagnostics tool or something to reprogram the keys.
I will check with local tow companies on the go-jacks.
Since I have power ... is there any way to raise the suspension ... override the ABC without the key? Since the key is not recognized, it will not turn in the ignition.
Thanks again for your prompt response.
Would there any way to reprogram the keys / sychronize the key with some portable device instead of having to take the vehicle to the dealership? That is the real problem which needs to be solved, the inability to tow the vehicle is secondary.
Of course someone at the dealership has the computer to do this , and its portable and can move around the dealership, they are just unwilling to make house calls to bring it to you
I can try and beat up on them and see what comes of it. Thanks again ...
sorry to hear that youre having a hard time with your Lorinser. I had the same issue when the keyless go card battery died on mine, took my dads audi and had the battery replaced, go back to the driveway to start the car and no luck!!
Had it towed by MB roadside back to the dealers who wouldnt admit they messed up but basically reprogrammed the key and it was all good again...!! Hope you get it sorted dude, battle your way through and hopefully it shouldnt cost you a penny
