Newbie Needs help. Just bought a S500
I have some concerns though. What is the normal temp I should see on the temp gauge? Mine shows 90-95degrees. However, I think it maybe running hot. If I put my hand on the front fender or hood approx. 12" behind the radiator it's almost too hot to touch.
It looks like the oil has not been changed in years!!! Lots of sludge when I opened the oil cap. First thing I had done was an oil change and the mechanic showed me a filter that was in 3 pieces and disintegrated. I want to do an oil flush but would like some advice before doing it.
Also want to do a radiator flush and tranny flush. Any do and don'ts??
can you please help as I love this car!!
Lots of ppl have had problems doing a coolant flush , I would only have a mb dealer do it . They usually don't charge too much. Too easy to get air bubbles in the cooling system and result in overheating
You should simply drop the trans pan and change the fluid and filter. Dont just get a tranny "flush" because A flush stirs up the particles in the Pan if it hasnt been cleaned. You can get a flush if you want after you clean out the pan
