S430 DRL fuse removal for HID kit
Old Jan 7, 2015 | 09:32 PM
cybertronicify's Avatar
2003 S430, 2014 E350
Hello everyone! I need to remove the DRL fuse (if there is one) and i can't find where the fuse is. I need to remove it because i don't want my HIDs on during the day time. Any tips will help!
Old Jan 9, 2015 | 10:51 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Just set your light switch to AUTO and it will prevent the headlights from coming on in the daytime. You don't need to pull any fuses.
Old Jan 9, 2015 | 12:07 PM
Really? When i set my lights to auto, the low beam comes on but much dimmer than low beam at night. The first Green light next to the switch is not on during the day time.
Old Jan 9, 2015 | 03:27 PM
ibeforreal's Avatar
Go into your instrument cluster (the one in the dash that shows the radio/cd/etc Using the controls on the steering wheel scroll until you see settings. Now scroll down to lighting. Change it from automatic to manual. Leave your light switch set to auto and you should be ok. They will only come on when the lights sensors kick in around dusk..............or if you drive through a tunnel.
Old Jan 9, 2015 | 04:39 PM
That fixed it. Thanks!
