Transmission oil level.
Old Feb 13, 2015 | 06:40 AM
al-sony's Avatar
s class w220
I change the transmission oil and filter on my s class w220 MY 2000 and the level is about 5mm over the maximum mark on the 80 degree section of the dipstick after driven 20 min city drive.
The trans works like it always has. I'm worried the 5mm over-fill will damage transmission?
Thanks.
Old Feb 13, 2015 | 06:47 AM
lganski's Avatar
2006 S430 4Matic
Remove the extra oil. You can put a hose in the fill tube and pull out just what you need to.
Old Feb 14, 2015 | 12:10 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
Buy one of those vacuums as Iganski mentioned. I change my oil via the vacuum process after I watched the MB techs do it. Haven't changed the oil from the drain plug in years. Just stick that hose down where my dipstick goes and vacuum it right out. Since the filter sits at the top of the engine I could change the oil in a suit and tie and not worry about getting dirty.
