Squeaking front suspension
Old Mar 9, 2015 | 04:56 AM
21vegasplayer's Avatar
2001 Mercedes Benz S430
Has anyone ever used these complete control arm, ball joint, / every rubber bushing replacement kits from ebay. Price usually around $399. ? Everyone tells me this should fix my squeak. I'm working on my 01,S430. Thanks
Old Mar 9, 2015 | 09:35 AM
wallyp's Avatar
2003 S500 2007 GL450
You can try a grease gun with a needle to grease all of the "sealed" joints on the linkage. That will sometimes cure the squeaking.
Old Mar 10, 2015 | 09:23 AM
SQUEAK IS GONE !! Thanks Wallyp
I located the squeak. It happened to be in the front air shocks. There is a flexible rubber boot attached to the bottom of each shock. I put a tiny pin hole in each boot and squirted some spray lithium grease. After a short drive around town....SQUEAK IS GONE. Thanks so much for the suggestion.
