Red EC light on
Can you share the information on rebuilding the coil pack?
1). Turn on ignition but do not start the engine.
2). Be sure climate control is powered on and both "auto" buttons are pushed in
3). Hold down the charcoal filtration button and the REST button simultaneously and the display reads "searching"
4). The codes can be scrolled through using the "A" button.
5). To delete the code(s) pop out the left side auto button and then the right one. Press the right button back in and then the left. Codes will erase and EC light will go off.
6). Press the EC button to return display back to normal display.
Now to figure out why the compressor isn't engaged, EC light off and plenty of hot air..Ideas anyone ?
Looks like I'll have to take the car to a shop with DAS ?
Disconnecting and reconnecting components, such as the engine suction fan, with the battery connected caused me all kinds of grief, only to disappear with the DAS connected and faults cleared in the control unit.
Seems to me MB put things like AC into a fail safe mode when certain pressures are not seen, and then must be unlocked with SDS.
Funny, same on my E350.
On the coil packs, look at the red inserts VERY carefully, as they tend to break down and allow the spark to goto ground.
On every misfire that I had, the actual problem was NOT the coil pack, but either the red inserts, or, water trapped in the spark plug recessions in the heads. Never wash an S600 engine with water!
Good Luck!
