not your normal 722.9 fluid & filter diy
Old Sep 27, 2015 | 04:23 PM
carbizindio's Avatar
2003 C32, 2002 S55, 1999 SL500, 2004 S430
For routine maintenance purposes I've decided to change the filter and fluid on my 2004 S430 with 722.901 trans.
Vehicle was leveled with all lift pads at the same height. Star used for trans temp. Trans fluid was left draining for 20 hours and here are the strange fluid quantities I ended up with.
Drained 8.5L
Initial fill 9.5L (overflow)
Drained at 45c 3.5L
That leaves 6L installed which is 2.5L less than what was pulled out. No glycol contamination, never noticed a trans problem before or after the fluid change since I purchased the vehicle about 35k miles ago. The only conclusion I can come to is some one over filled the trans in the past, maybe when the pan modification was implemented.
Old Sep 27, 2015 | 05:09 PM
tusabes's Avatar
Mercedes
I don't understand why you drained 3l afterward ?
Old Sep 27, 2015 | 05:16 PM
SOP for 722.9 fluid level adjustment. Install drain plug when fluid level is aligned with (white) overflow pipe at 45C.
