W220 - S320 (1999) does not change Gear
Hello all ...
I have a problem with the gear, the gear can not change and the panel will come out "AIRMATIC".
Gear will be back to normal when I'm off the engine and start it again, but when I put to the "P" or "N" and return to "D" it will happen again. I get off the engine and start again, sometimes back to normal and sometimes need to do 2 to 3 times (off the engine and start it again ) to return to normal.
Anybody here has ever experienced a problem like this? What's the cause? Any sugestion or solution for this problem?
Thank you.
