Distronic problem W220
Old Dec 7, 2015 | 11:13 PM
MB-W220's Avatar
Mercedes S class W220
Hello all,
In 'm a new member on the MB world forum . I live in the Netherlands. I have been a 1.5 year a proud owner of a Mercedes S Class W220 . Recently I have a problem with my Distronic system . I keep getting the message '' clean sensor '. Now I have a question ? How do I know if the ECU module or sensor are defective ? The error code is C1000 .
Have any one get this message before and fix the issue?
Thenk for your help.
Old Dec 8, 2015 | 10:47 AM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
did you clean the front of the distronic sensor (the round radar antenna behind the grille), and the clear plastic shield in front of the grille?
BTW: update your profile to model # and year!
Old Dec 8, 2015 | 01:04 PM
MB-W220's Avatar
Yes I did. The sensor and grill are clean. I went to the local car service (non mb dealer ) Thee checked the distronic system and get an error code c1000 commonation problem. I think the ECU module is not good anymore, but it can be the sensor also.
Old Dec 8, 2015 | 08:28 PM
kraut56's Avatar
If they used a DAS/SDS diagnostic system, the fault code will tell them in WIS how to isolate the fault.
Old Feb 23, 2016 | 09:09 PM
MB-W220's Avatar
Update ,
My distonic module was defective. Ireplaced an 2 hand one. Now I have the same problem “Clean sensor’’ error . MBdealer says I most change the distronic sensor behind the grill
Can anyone till me is it easy to replacethe distronic sensor?
All your suggestions welcome.
Old Feb 24, 2016 | 01:58 AM
kraut56's Avatar
you should be able to get a sensor from a junk yard (wrecker)
May need a DAS reset after that.
Old Mar 15, 2016 | 12:13 AM
MB-W220's Avatar
Update.
My distronic work agene. I replace the sensor and very think works fine.
