Wheel inner seal
Wheel inner seal
Hi everyone, I have a 2000 S430 and I was in process of replacing the inner and outter wheel bearing for the front. I ordered a wheel seal along with it, when I was tearing the wheel hub out and I noticed the seal I order does not fit on it, since I noticed there a ABS reluctor over it, and after discovering that the seal I got from local part store is incorrect, so I ended up reusing the wheel seal. now here my real problem, after putting back together and now my speedomter is not working and the ESP light was blinking when I tried to drive it. SO my thought was the ABS sensor, which wasn't the problem, turn out was the reluctor could have been warped after i tapped in the old wheel seal. Now my question is how do you get the ring off with the seal after I found out that the wheel inner seal comes in with the ring, since it doesn't seem to budge or come off at off? I was thinking of cutting it out but I don't want to risk damaging the hub. Any suggestion?![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
