iCarsoft i980
I'm thinking of buying a scanner/reset tool - iCarsoft i980. Does anyone have one and if so, will it do the following things on my 2000 model W220
- Reset my airbag light
- Tell me if I have a bad wheel sensor
I have the dreaded ESP/ABS and 'heavy' steering issue. I've checked everything I can think of, my brain is fried, and I'd really love to know if a bad wheel sensor is causing it, rather than just start replacing gear.
I would take it to an Indy but I don't have any within 2 hours of where I live. There is a local garage but they're not big on Euro cars..
I did note that the iCarsoft i980 doesn't appear to do CLK C208, only the 209 body. This would be a slight shame if so as I also have a 208.
If anyone can help then that would appreciated.
cheers
ps I have a standard OB2 reader but that just picks up engine codes..
If you search the forums there are hints on cleaning the seat belt buckle latches to fix the SRS
It sounds like it still might be worth my while buying icarsoft 980. If I can pinpoint the cause of my fault and replace the item, then I can take it somewhere to have the fault cleared. Here in Australia, I'm up for $200 AUD for the iCarsoft i980. I can see on eBay an MB Star SD Connect C4 for $750 AUD as a comparison.
I've spent so much lately on parts and tools that my wife will wonder what I'm doing!
Just go into it knowing that the i980 is not a full diagnostic tool and you may find yourself frustrated at times. If it does not connect to a module, it does not mean the module is bad. It is most likely the scanner. It's not consistent either. For example, I can connect to some W220 S500 ESP modules but not others.
Used Dell 630 = about $ CAN 120.00 (with increased memory and 120g HD)
Set of 14 Xentry DVDs = $ US 70.00
MB C3/C4 cable and MUX set = about $ US 220.00 (from Alibaba)
Look into it!
I have not recieved my setup yet so I can't rate the quality of the product but I have read in other forums that DHgate is a very highly rated supplier. However, that said, you should do your own research before making your purchase. Do a search here as well as Benzworld. Much experience has been written about and shared. Be sure to search each forum in its entirety.
My opinion is that you will always be lacking with anything less than an SDS setup and regret a lesser purchase. I have decided to stick with Mercedes for the near future so every advantage I can get to keep the ownership costs down and stay out of the dealership network will help make that happen.
Good luck,
Bob
The link to the product was interesting - their ad where they compare their product to others is a bit frightening. I guess there are some Chinese companies selling PC boards without all the components! That might explain a cheapo reset tool I had for an old BMW - it never worked and there appeared very little inside it!!
I might regret it now but I went ahead and ordered the i980 early this morning before I saw your post. I think I just set myself a mental $ limit and over that I was looking at a different strategy.
I realise now most of my previous car experiences have been largely pre-diagnostic type vehicles. Too many old cars have influenced my thinking!
cheers
Jim
