MRECEDES S600 BITURBO HELP!!!!!
Old May 25, 2016 | 12:47 PM
Phil Huggybear's Avatar
Mercedes S600 BITURBO W220
Hello this will really fox you all....ok I have just bought a w220 S600 Mercedes BITURBO with the SRS light on........so we plugged the diagnostics in autologic.......the chassis number in the ecu is correct the SRS comes up chassis as all letters and says it doesn't recognise the EIS chassis number and the EIS comes up with a different chassis number basically from an older non turbo S600 so someone has changed it for a second hand part from a different model!!!! I have NO steering lock....BUT the car starts via the key and everything works bar SRS fault light....I need to know HOW can it start car when it has a different chassis number to the engine ECU? Also the keyless go works and I have made sure its picking up from the key......all I want to do is get the SRS light off......any ideas???
Old May 25, 2016 | 09:10 PM
wallyp's Avatar
2003 S500 2007 GL450
The first thing I suggest is to hook up the STAR/DAS and see what the SRS problems are. The Diagnostic Assistance System will tell you specifically what is wrong. Otherwise, you are groping in the dark.
One of the more common SRS faults is the passenger seat sensor...
