05 S430 no air blowing
Old Jun 30, 2016 | 04:08 PM
Mpassion's Avatar
Mclaren SLR, S430, G500
Hello,
I have replaced the blower motor (meyle) and Regulator (behr) yet have no air at all.
1. console says error diog which I presume is ok.
2. console bar 6v as air raises appears functional
3. where can I service my benz DC/VA/MD?
A blown fuse or defective new regulator, or over head temperature sensor malfunction?
Btw I was well pleased how simple the blower motor replacement was as instructed here.
Any guidance is greatly appreciated.
Old Jul 1, 2016 | 08:39 AM
wallyp's Avatar
2003 S500 2007 GL450
Check the blower fuse - on my 2003 S430, it is Fuse #33, the 40-Amp fuse at the front of the right box under the hood. (Remember, left/right are always from the viewpoint of the seated driver.)
Old Jul 1, 2016 | 03:24 PM
Mpassion's Avatar
Thanks Wally, I will have a look.
Yesterday it was 80 outside and the A/C blew cold and operations were normal. I guess that means the fuse is good? Today, nothing no air.
per instructions
W220 Automatic Climate Control Service Menu Version 4.pdf
Parameter NR.01: (In Car Temperature Sensor (N70b1), Overhead Control Panel (OCP) (N70) reads "0". I guess this is the sensor by sunroof-dome lights?
Would replacing overhead sensor solve issue at hand?
Old Jul 11, 2016 | 11:44 AM
Mpassion's Avatar
Wally,
the first 40 amp fuse was broken on bottom half. The fuse doesn't resemble any of the fuses I overlooked it.
Lesson learned don't change regulators or blowers until you verify all fuses.
Cold A/C is lovely in the summer.
thanks
