How to control rear ac from command in S500 W220 Model 2004
How to control rear AC from command in S500 W220 Model 2004
Hi guys,
I would like to inform you that I found out that in my 2004 S500 W220 I can control the rear ac operation:
1. Let us say the rear AC is switched off.
2. In the front ac, press and hold for more than 3 seconds the center button, which is used to increase/decrease the blower.
3. You will see that ac display screen changes and displays a picture of rear ac with a 0 at the bottom. Note that if you do nothing for another 3 seconds, the display will revert back to original display.
4. With the new display of rear ac, you can press the 0 button on fron ac and the rear acc will start. Similarly you can also change the temp using the front ac buttons.
I hope it helps as I think I have not read about it on this forum and this might be some thing new for every one.
