Problem with aromatic after repair.
Old Dec 27, 2016 | 09:14 AM
Robson921's Avatar
2014 C300 4MATIC LUXURY & 2012 GLK 350 4MATIC
Problem with airmatic suspension after repair.
Hi everyone,
I got my first S500 little over 2 months ago my problem is I replaced all control arms in rear left tire cuz it was damaged. Then after repair I started the car everything was okay to the point that the compressor was on after I shut off the engine it didn't want too turn off so I unplugged the battery there was no problem like that before. I also noticed that the air line was having a small hole in it I don't know if that can be a cause. I plugged in battery after a while and it was still the same thing so I tried to raise the car up with the button on the dash the front went okay the back a little bit too but not like it was before. Is there any fix to that please help. Thanks a lot 😊
Old Dec 27, 2016 | 10:00 PM
wallyp's Avatar
2003 S500 2007 GL450
Go to the encyclopedia in the light blue area at the top of the Forum - find where it says "...START HERE..." and start there. Find the Airmatic pages, and learn how to replace the relay that controls the Airmatic pump. If you let it run continuously, you will burn the pump out very quickly.
Then continue reading thru the encyclopedia and learn how to find leaks in the system.
Old Dec 27, 2016 | 10:19 PM
Robson921's Avatar
I see yeah I didn't let it run for a long time I disconnected the battery after few minutes. After like 15 minutes I tried to plug the battery back in but same thing the compressor kicked in right away then I started to having air ride visit work shop only message and ESP message as well then the abs message popped up too ... in matter of fact the car is still rising the front normally and rear a little. But it's not all the way down tho.
Old Jan 27, 2020 | 09:44 PM
E63//AMG's Avatar
W211 E63
Old Jan 28, 2020 | 09:36 AM
wallyp's Avatar
Basically, you caused most of the new problems by disconnecting the battery, and you will have to fix them by doing the required resets. These resets include:
- With the engine running, turn the steering wheel all the way to the left stop, then all the way to the right stop.
- Lower the driver's window to the bottom by pushing the switch thru the detent (auto lower position), and hold the switch for five seconds, then raise the window to the top by pushing the button thru the detent (auto raise) and hold the switch for five seconds. This resets the window by telling the computer where the bottom and top are.
- Repeat this for every window.
- Repeat this for the sunroof.
- Repeat this for raising and lowering the steering column.
- Repeat this for moving the steering column in and out.
- Repeat this for moving the seats forward and back.
- Repeat this for moving the seats up and down.
- Repeat this for moving the headrests up and down.
- Repeat this for moving the backrests back and forth.
- Repeat this for opening and closing the power trunk if your car is so equipped.
- Try to remember that you should try to avoid disconnecting the battery unless it is really necessary.
Do the research recommended in Post #3 by going here https://w220.ee/Airmatic and repair the leak. The compressor will run until you repair the leak or until you burn it up ($$$). If the compressor runs continuously after the leak is repaired, remove the control relay until you can get a Hella relay (not a cheap Chinese relay) to replace it.
