w220 Key Fob battery change
hi, 01 s500....one of my remote fob sometimes seem to work intermittently.... no red light when buttons pushed.... i couldn't lock the car.... about an hour later, i was able to see bright LED again... the car started fine with the key... didn 't check whether i could start the car when the LED wouldn't come on. . . .
it would have been worse if i was able to LOCK the car but couldn't unlock....
anyway, this key FOB has a crack on the Unlock button from use... maybe the wife used nail on it due to frustration...
Is there a battery change for these things???
any similar incidents guys?
Jim R
01 s500S , biXenons
46K miles
so. calif.
jjrho@adelphia.net
Jim R
01 s500S , biXenons
46K miles
so. calif.
jjrho@adelphia.net
marta
You can open it up by taking the metal key out and sticking it the horizantal opening and, there, you should find a battery. Battery shouldn't cost that much, and you should be able to find it anywhere.
'05 A4 1.8TQM6
yeah, usually intermittent operation is a sign of the battery going.
it's a few bux for the battery and u can change it yourself. Though, the battery I haven't been able to find outside the dealer? I've tried home depot, cvs, electronic stores...no one has them??? I've had to go back to the dealer to get the batteries
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
1999 E430
Had similar problem. Drop by the dealer get a new batter, I am not sure how much it is exectly but it's only a few dollars and just ask them to change it right there they should do it no problem.
