ABC warning on older model and shift slipping
After parking the car the message despaired, weird its happens 3 times today right after Transmission slipping is to neutral in various speeds
Also most wired this car should not have ABC
Any advise is greatly appreciated
has it rained recently ? Sounds more like some electronics problems , check under the windshield plastic grille to see if the reservoir is filled with water . Also check the tcu in the underhood electrical boxes to see if it has fluid or water on it
If there's no problems there , lastly check how old your battery is , could be errors from a weak battery
the windshield plastic is clean
tcu - both of them is in great condition
battery was dead and replaced 2 weeks ago
