W220 Air Suspension Leak
Old May 20, 2017 | 11:02 PM
lynchmichael84's Avatar
1990 350SDL
The car falls randomly over night, not my car a customer. I used the SDS and narrowed it down to a leak between the valve block and compressor. I cannot find a leak in the lines. Is it possible for the valve block to have a bad valve or do the compressor most likely have a internal leak?
Old May 21, 2017 | 11:46 AM
wallyp's Avatar
2003 S500 2007 GL450
It is easily possible to have a faulty valve in the block. Rebuilding is reportedly not too difficult.
Old May 23, 2017 | 03:23 AM
cybertronicify's Avatar
2003 S430, 2014 E350
The line between the valve block and compressor should be pressurized, there is a one way check valve on the compressor that might not be holding sealed.
Old May 23, 2017 | 07:03 AM
doni01's Avatar
2013 S550 4MATIC
I pm'd you as well but if you need a good working valve block let me know.
