2001 v12 Vacuum Help!
Can anybody tell me what #320 in the attached picture (Part # 1370180209) attaches to? I know it goes to the other breather hose and the throttle body, but where does the third port go to? any help would be appreciated...
Hello, this is my first post on the net. That connector in the drawing should only have 2 ports. It provides vacuum to breather vent on the oil water heat exchanger under the intake manifold and a purge valve located on the firewall on the left (assuming you have Left-Hand drive). I hope that helps. If you have EPC look at section 060 (closed fuel and evaporation system) part 200 to see what the hose and valve look like.
