Cant get air to struts
Old Sep 19, 2017 | 12:05 AM
kccobra's Avatar
s430
Ok so I am new here, but all I see is people with issues of pump running all the time or leaks. I have something a bit more indepth, or so I think.
I have a 2002 S430 and I also have an autel 908 pro so I can cycle the pump on an off, but it never charges the struts.
So the pump will never turn on by itself, it will when I power it up with the scanner. I have replaced the pump, the relay, the valve body, and checked for leaks everywhere. When I cycle the pump manually I can here it charging as it sounds like its getting under more stress. I pulled a hose off the front pass and driver to test for pressure and it is very weak at best.
Would the pressure valve be bad on 2 pumps? What would cause the pump to never turn on? Has anyone had this issue? Need some advice on what to check and were to go from here. Thanks!
Old Sep 19, 2017 | 10:02 AM
wallyp's Avatar
2003 S500 2007 GL450
The Airmatic system is much more complex than you realize. The pump does not supply air directly to the struts. The air flowing to the struts is individually controlled by a computer, based upon ride height sensors.
Start by going here https://w220.ee/Airmatic and doing some reading. You will need to do some system testing and checking.
Old Sep 19, 2017 | 11:37 AM
kccobra's Avatar
s430
I think I am going to buy a computer at this point. Seems after reading the wiki there is a good chance that is it. I was working fine and just stopped. With the autel when I try to fill each bag it will just put pressure in the tank and never make it past the valve block, you can faintly feel the air pass in the hose going to the strut.
Old Sep 25, 2017 | 10:34 AM
kccobra's Avatar
s430
Computer fixed my issue. Cant believe after reading all these issues it was that module.
Old Sep 27, 2017 | 03:28 PM
S430AMG's Avatar
2006 S430 AMG
Curious, how much was the computer?
Old Sep 27, 2017 | 03:34 PM
kccobra's Avatar
s430
$25 shipped. It was not bad at all. I am glad I didnt go all crazy with the pump and valves, just narrowed issue down and done. And to be honest, the system is pretty simple compared to what it seemed at first.
Old Oct 9, 2017 | 10:00 PM
Ken_Tak's Avatar
2000 S430
Hi
Very curious about this. Can you explain what you mean by 'computer'?
Can you provide details of what and where you bought? Where is the unit located on the car?
Old Oct 11, 2017 | 09:00 PM
S430AMG's Avatar
2006 S430 AMG
Nice, where did you get it?
cheap enough to replace at any sign of air suspension trouble...
Old Oct 24, 2017 | 04:29 PM
kccobra's Avatar
s430
Ebay
