Limp mode after replacing conductor plate
Old Sep 30, 2017 | 03:09 PM
Montenegro's Avatar
2000 S430
2000 S430. Vehicle had an input speed sensor malfunction along with the dreaded conductor Pin / ATF in the TCM issue. I replaced the conductor plate along with the PIN / gaskets / new fluid etc. Now the speed sensor code is gone but instead I got a P0748 check engine code / and the TCM reads 006 / 102 fault code “ Y3/ 6y1( modulating pressure control solenoid has failed ) I tried resetting the code with my MB II but no luck . I also replaced the tcm with one from a junkyard ( same part # ) still same codes . Any suggestions ?
Old Sep 14, 2018 | 10:45 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Have you checked the wiring and TCU for fluid intrusion?
Old Sep 15, 2018 | 02:09 AM
tusabes's Avatar
Mercedes
Think you might need the whole valve body not just a conductor plate
