Trunk Lock Electrical Issue - please help diagnose
i have had an ongoing issue where the trunk lock actuator does not unlatch. I have tried repairing my trunk lock actuator (replacing the black puck) and when that didn't work, I replaced the trunk lock actuator two different times (with new parts both times, because I thought the first new part was DOA). I still have the same issue. When I ran my scanner, I see the following error:
B1446-002: Component Y65/3 (CL remote trunk lid release valve): Short circuit to ground or open circuit.
Assume something is up with the brown/blue wire that goes to the trunk lock actuator. Can someone please help me diagnose to figure out what’s going on?
Thank you!
I spent A LOT of time and money on this issue only to find out that my lock actuator was okay and it was just a frayed wire. During the process, I managed to close my trunk with the trunk lock rod disconnected from the actuator. Unable to open the trunk with my key blade, keyfob, or trunk release button, my "best" option was to cut out my tail lamp to access the trunk lock mechanism. In the process, I managed to slice the tail lamp wiring connector in half. I got lucky and found a set of tail lamp connectors on eBay that were donated from another W220. This whole process sucked.
Leaving this info here in case someone else runs into the same issue in the future.
I had the same exact error code on a 2003 CL55 and the brown/blue wire in this car’s retractable wiring loom was broken too. Reconnecting this wire took care of the B1446 trouble code.
This car also had other broken wires in the retractable loom and reconnecting those restored functionality to the rest of the components on the trunk lid.
Additionally, I found out a lot of the trunk components from the W220 carry over to the C215. The PSE pump, for one, works after coding.
Secondly, I needed to replace the right trunk hinge, and the CL55 part was discontinued. The W220’s trunk hinge is completely identical, and could still be purchased. It fit perfectly!
Here are some part numbers:
Trunk hinge for C215: 215 750 06 87
And for W220: 220 750 06 87
I hope this helps someone, like @homejones did to me.
