Can't get accelerator pedal loose, 10mm nut spins and spins
No problem, I sez, I've dealt with this sort of thing before, like carriage bolts in wood where the head wants to spin. But if you use a pry bar to pry the pieces apart, putting some tension on the bolt, the "teeth" in the head will usually bite enough to let the nut break loose. So I got a 1" wood chisel, wedged it under the base of the pedal assembly, and pried up with one hand while ratcheting with the other. Still nothing. Here's a picture:
Any ideas on how to get this dude off? I plan to try again with a pry bar, just didn't have one at hand before. Would get more pressure on it, but I'm also worried about pulling the stud out of the floor. Does that look like a locknut to you? I think it is. Is that factory, or would someone have added that?
I thought about using a microtorch to melt the nylon out of the nut (with a fire extinguisher handy), but 1) it would probably just run down into the threads, and/or 2) it would probably re-solidify before I could get a socket on it. And make the inside of the car stink.
I could cut the base loose from the stud with a Dremel or similar, then when I get the stud/nut by itself I could hold the stud with a needle-nose Vise-Grips while turning the nut with a wrench.
Has anyone else run into this? The new pedal assembly is in the mail, so I don't have one to look at, but I'm guessing the throttle position sensor at the top isn't easily swapped by itself? Asking in case replacing that in situ was an option.
Thanks,
Mike
Turned out I was using the wrong size socket and that's why it kept spinning.
Maybe try a metric socket one size smaller than the 3/8".
I had resistance almost the whole way off the stud when removing it.
Keep trying.
