S32 AMG engine swap project
Hi guys, as i'm new to this forum, i would like to share that i swapped the C32 Engine, trans and TCU to a S320. The ECU of the C32 AMG was damaged without the function of processing engine start signal so i'm stuck with the M112 engine ECU. The S class is full M112K engine not just swapped the intake. Right now there are so many things that i still need to take care of. Wish me luck.
W220BossDon (03-19-2022)
The M112K ECU(031 545 18 32) is not compatible with this existing EZS (215 545 02 08), they only known work with EZS(215 545 00 08, tried it when the immo is still not yet corrected, the engine cranked and ignited for a second), but i damaged the EZS chips that makes it unable to recognize position H0, therefore unable to use this EZS to power the C32 M112K ECU.
