airmatic - squeak/squeal when starting off in low mode.
Really love the car but can't afford to buy it and repair it immediately or soon after.. unless it's an inexpensive fix. I've been reading how these airmatic suspensions are a problem but most of the squeaks have to do with bumps.. and not just starting off from a stop for the first time.
What do to... what to do.. any guidance as to what this issue might be and the cost of the fix would help me decide whether to buy this car or not.
thanks
The other button is to control the stiffness of the shocks(dampers). There are two positions in some cases, three positions in others. This has no effect on the ride height, just the firmness of the ride.
Hands-on inspection is about the only way that you are going to find the source of the noise. It could be a small stone rubbing against the brake, a bent brake shield rubbing against the rotor, something rubbing against a rear axle/half-shaft, etc., etc., etc. Did you apply the parking brake? If so, could be something in the parking brake rubbing.
