ABS Issues
ABS Issues
Hi guys,
My Brake pedal is pulsating at low speed. Turn up the volume to hear the brake pedal vibrating. No abs or esp lights on the dashboard and no error codes on the obd reader. Also when I'm driving I get my ESP turning on on low speed and I don't know what is happening. I went before that to mechanic to check my ABS ring from where the sensor reads the speed and etc. and after they have cleaned my ABS ring this issues happens. If anyone had this issue or similar or any suggestions would be highly appreciated.
2003 S500 2007 GL450
What were the problems before the cleaning?
What were the problems after the cleaning?
Does the pulsating vary with speed, or always the same frequency?
Did you intend to attach a video?
Thank you I will try that as well but the issue was that all mechanics says they dont see any issues with the RING and thats why they try to clean it instead of replace it . Another questions do you know if the RING I can buy it separate I mean the ring only for the ABS?
2013 W204 C63 AMG, 2008 W221 S65 AMG
I would get the 4 wheel speeds data logged and drive the car at slow speeds and see if there is a consistent error in the speeds reported. If so its likey to be a mechanic issue with the ring. If not, then its possibly an issue with the ABS ECU etc.
If that is the case, why do they suggest cleaning a ring that looks perfect?
lemara (04-24-2018)
Front axle they are part of the seal - A0259971647 (at least for my 221.179)
No problem!
