Mercedes S500 won't shift out of first gear
Don't assume that we know what you did - tell us exactly what you did to do the reset.
What do you mean "...shifts hard into Park, Reverse, Drive...". Do you mean that the shift lever is hard to move? Or do you mean that the shift lever moves normally, but the transmission jerks or slams as it shifts into Park, Reverse, Drive?
Have you tried manually shifting from first to second by moving the shift lever to the side?
Does Reverse work normally?
You mashed the pedal too hard during your transmission control unit reset and wrecked the kick-down button built into the gas pedal. If this button is messed up, the transmission control unit doesn't know what gear you're in or supposed to be in so it won't shift.
You definitely need to get this diagnosed by reading codes, preferably with the Star DAS, and find out what actually is wrong and why your car is acting up.
Good Luck!.
Ps. I could be completely wrong, as this was just a guess. For all I know, it could be your tire pressure is too low. :p
