IS SHE WORTH?
Hello guys, I recently purchased a used 2006 s430 w220 4matic Mercedes and so far I had a few issues with it.
1: leaking washer fluid from a hose which I went to the parts store and fixed with a $5 hose
2. The command unit wasn’t working so I did some research and found out the cd changer in the rear wasn’t powering on, I purchased a fiber loop tool and the command unit is working now🤓
3. The cluster is displaying ……… there the Milege, nav, and audio information would be, so I figured the cluster was a different one. I called the mb and gave them the vin# and got the correct cluster model for this car. I then went on eBay and found the correct model, installed it and still nothing. I figured I might have to connect it to the star to fix it, don’t know yet I’m still figuring it out any comments would be grateful.
now to the question you guys may ask how much, $4900 let me know if it was worth it thank you
