Start problem
Old Jul 26, 2018 | 10:03 AM
Mario Misiek's Avatar
w220 w140
Start problem
Issue with w220 S430 01'
I have some strange symptoms which I do not understand. Car was driving fine and suddenly I was unable to start.
When I turn key nothing is happening. No faulty codes, good battery.
After few attempt I just shift to N and car started. Right now car is driving ok but I still don't understand what is happening.
My gearbox was serviced 6 weeks ago. Can be related to this service ??
Mario
Old Jul 26, 2018 | 09:12 PM
wallyp's Avatar
2003 S500 2007 GL450
Possibly - one of the rules for troubleshooting faults is to look at the last few things that you touched. If the "no-start in PARK", but "start in NEUTRAL" is repeatable, a loose connector on the shifter would be my first guess.
Old Jul 26, 2018 | 09:20 PM
w220 w140
Last think what was done is engine oil, gearbox fluid, full flash of radiator, airmatic pump. What you mean by loose conector on the shifter??
Old Aug 7, 2018 | 05:26 AM
w220 w140
OK I still didn't find out what is going on with car. Right now I'm not able to start at all. I can turn key many times and is nothing happen. I heard funny noises under the hood so I opened. I found out the fan was running. It is happening every time if car dont want to start it. Today I notice if car don't want to start it I dont see gearbox on cluster. I can switch off and on and off and on 3 to 5 times and final I can see gearbox gear and car is starting. What is going on Conductor plate, TCM or electronic shifter. After start car id driving but shifting is not smooth.
Thx for all help
Old Feb 15, 2019 | 12:17 AM
Bill Rodriguez's Avatar
S500 w220
Starting at random fixed for me
Crank position sensor.
