Battery died locked out of trunk
Old Aug 6, 2018 | 09:42 PM
Unionboy483's Avatar
Mercedes s500
I already tried jumping the starter below the passenger side floor panel and won’t charge due to a possible cross wire or something that’s draining the battery
Old Aug 7, 2018 | 01:24 AM
tusabes's Avatar
Mercedes
you don’t jump start from under the floor you just apply power there under the floor so you can hit the trunk release .
If the trunk release isn’t working when power is applied under the floor you pull the plastic surround under the rear license plate to pop the trunk
most likely what has happened is you blew the main fuse under the carpet where you are trying to jump start it
Old Aug 7, 2018 | 09:19 AM
Mercedes s500
My brother in law tried doin this yesterday but that outside panel wasn’t poppin out he thought it may have been glued or something
Old Aug 7, 2018 | 09:30 AM
wallyp's Avatar
2003 S500 2007 GL450
Since you may have blown the main fuse, make sure that you are on the battery side of the fuse when you are trying to charge the battery, and not the load side. If this works, check the fuse and replace as necessary.
Old Sep 24, 2018 | 05:04 AM
Mercedes s500
https://youtu.be/r3skRToDheM
thank you this was very helpful sorry for the late response I’m just back on this group after a while
