No power coming to airmatic compressor
I have a 2001 S500, I have tested everything and the compressor is still not getting power, I have ran power straight to the compressor and it kicks on fuses and relays seem good. Anyone got a solution
Quick and easy to test - once you get to it. Pull off the connection, and check for continuity across the sensor connections.
but it’s almost always always the relay itself that’s bad
I don’t know how you tested the relay but just because you hear it click does not mean it’s good internally it could be dead
if a jumper on the relay socket will start the compressir but just using the relay is not working, then the relay is not good. Again, these airmatic relays fail all the time, get a new one.they are $10 Yes, it’s possible that something is not triggering the relay to activate,
