05 S600 Left Tail light wont go out. Defective display
Yes JohnJbaby, not only you have to make sure you clean the drain Heed Plenum /drain hole /valve. Now make sure you pick up the carpet specially on the right passenger side front and back, because there will be a lot of water under the carpet. If not after you start driving the water will flow back there again and short out the SAM and the other electronics.
a dehumidifier on top will not get to any water under the foam carpet pad .,carpets must be pulled up
