intermittent crank no start - NO CODES - NEW CPS
Wondering if anyone else experienced this. I looked over the forums but always found CPS is bad or car has codes. Sometimes, not every day maybe 1 time a week, the car (2004 S430 4Matic) cranks and no start, try again and it starts. No codes at all and no other noticeable issues. I had a CPS go out in the past on my other Benz and it all seemed to be the same as that one so i did replace the sensor. after a few days go the same problem.
Does anyone have any ideas? With the icarsoft attached, what should I be looking for?
look for RPM during cranking. chances are it will show it.. I've had this issue with my CLK55. the only known fixes are 1) lubricate the flywheel (yes, really) 2) replace fuel pump and filter (pressure issues) and 3) replace starter (slightly too slow cranking rpm)
I believe my issue was the starter because it started firing first time when I jumped power directly to the starter.
Loggato,
Thanks. I dont think its my starter because it cranks fine, no slow cranking at all.
I do feel stupid though now, the fuel filter! That is something that probably should be changed anyway and I suppose could be the reason. I tend, sometimes, to ignore the basic stuff thinking it is something in depth and technical. I think thats becuase cars have become so computer dependent, the basics get forgotten sometimes. I will try the filter and see how things go.
I assumed you tried the crankshaft sensor. Have you looked at the camshaft sensor?
My 04 S430
2017-06-06 0232103037 Bosch Camshaft Position /Reference Mark sensor replaced
2018-06-01 Bosch 0261210170 Crankshaft Position Sensor replaced
My 04 S430
biker349 (04-10-2020)
DrDoe
Thanks, I thought about that but I was assuming some sort of code would come up with that sensor going bad. Or I was hoping to find out what to look for on the scanner that may tell me this. Like I said no codes. What I will do first is replace the fuel filter this weekend and see where that takes things.
Hayır marş deyil.
[QUOTE = loggato; 7563957] kranklama sırasında RPM arayın. muhtemelen gösterecektir .. CLK55 ile bu sorunu yaşadım. Bilinen tek düzeltmeler 1) volanı yağlayın (evet, gerçekten) 2) yakıt pompasını ve filtreyi değiştirin (basınç sorunları) ve 3) marş motorunu değiştirin (biraz çok yavaş marş rpm)
İlk önce ateş etmeye başladığım için sorunumun marş olduğuna inanıyorum gücü doğrudan marş motoruna atladığım zaman. [/ QUOTE]
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
HUH???????
This is an English language forum - you want me to post everything in German - or French???
