Key fob won't turn/start car, lock/unlock doors
Has it been raining? Open the hood and use a good light to look down to the bottom of the HVAC plenum under the black plastic grille. Any trace of water in the plenum is a very bad sign. If the drain is plugged, water will fill the plenum and overflow inside the car under the carpet. There will be no visible water inside the car, but it will cause major electrical issues.
Update
So, after hours of Google and YouTube searches, phone calls, finally figured it out. Literally just a 7.5 fuse in the cockpit on the passenger side. Apparently (in my opinion) this fuse controls far too many functions including steering wheel lock, heated steering wheel, ignition switch... Appeared as if the box itself was shorting the fuse soon as I put in a new one. Ultimately removed the fuse box itself inspected the wires saw nothing then placed in a new fuse and voila!! Key fob works, steering wheel went back to position and everything functioned as it should. Hope this helps someone else in the future.
