MAN O MAN please help Radio content
Well this journey with the S430 has not been fun...the locks, the leaks from a light mind you....now my GD radio?
OK so everything was working fine and then one day the radio turned off....would come on, but the Benz Logo appears, but shows off on the instrument cluster. now here is the weird part, when i mess with the fuses, i can get the system to come on every once in ahwile...then yesterday the radio came on and wokred fine. stopped parked, turned car off, radio came back on....then while driving shut off, hasnt come back on....soo i few things..seems like a loose something, so i checked everythig i could...nothing is loose...played the fuse and took out the red holder cleaned connections and still nothing...some say my gateway, can itest that by pulling the fiber out and see if the light passes through? is the fuse box bad? or does pulling the fuse reset the MOST ring and works for a bit until a component fails closed? i would appreciate any help or suggestions...thanks
