2003 Front Drive Shaft help
Date registered: Aug 2017Vehicle: 2012 GL 350 BluetecLocation: IdahoPosts: 2Mentioned: 0 Post(s)Quoted: 0 Post(s)(Thread Starter)I just replaced the OEM front drive assembly on my S430 with a Durashaft brand. Now I'm feeling & hearing virbration above 40 mph. It also gets worse with an incease in speed. I can even feel it in the steering wheel. Any ideas? I did mark OEM shaft & both flanges before removing shaft but inadvertently wiped off the marks on the differential flange and transfer case flange. So when installing the new shaft, I had no idea on where it should line up on both ends. Could that be my vibration cause? If so, how do I correct it & eliminate the vibration?
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
you can phase the front drive shaft to the rear drive shaft with the raised markings by searching both forums.
Are you talking 4matic??
