Airmatic Pump Replacement
Does anyone know if "reprogramming" is required following pump replacement?
Thanks.
https://w220.ee/Airmatic
This is one of those situations where in an effort to save time and inconvenience an increase in both has resulted. I will spare you all the details, but I had a problem with the airmatic where the car felt a bit stiff and high and I had the "Airmatic - Visit the Workshop" error message. Within a few days my wife was driving the car and when she returned to the parking garage after work it was sitting too low and displayed the "Too Low Don't Drive" message. Towed by flatbed to a mechanic close to our home who said he was knowledgeable and experienced in airmatic repairs.
Vehicle was diagnosed with a right front strut failure and a burned out airmatic pump. However, he purportedly quoted me for dealer parts and over $2k total for one strut and pump replacement and install. I instead purchased Arnott strut and pump myself. His shop installed them (they have lifts but did not use a lift for the install and said the install was very difficult?!), called me to pick-up car saying it was ready and good to go, but when I got there (mechanic now out of town) and only after I requested to inspect the work and drive car once I was in the car the non-mechanic nephew of the mechanic (the "service writer") told me the Arnott strut was defective so the vehicle is still showing the same error code with the right front strut (I don't have the code with me but it relates to the right front strut valve). I'll spare you details regarding the additional interactions with the shop and mechanic but suffice it to say I took the car home. Maybe it is as simple as he says (bad strut) but I'm not confident in anything I am hearing from that shop as they clearly would have let me pay and drive out of there without saying anything further.
The car shows the "Airmatic - Visit Shop" error message. It holds suspension, rises when you push the rise button and seems to be working to the extent I can tell. However, it seems perhaps stiffer than normal and I have noticed a very strong vibration and noise for brief periods I have never felt before, which I suspect may be the pump vibrating. I really haven't driven the car for more than a short time as I am concerned it will progress again from Visit Workshop to Too Low Don't Drive.
I pulled the right front wheel off on Sunday to inspect the strut install. The control cable plug was facing towards the midline of the car rather than facing outward as it is on the other side and it looks like the strut control cable plug has been pulled almost fully into the wheel well from the engine compartment (perhaps this is correct). The cables are seated in the plug and the pin holding them is in place. I did not inspect the pump installation.
I am likely just going to take it to the dealer, although I could also get a replacement strut and see if that resolves it. The vehicle is a 2003 S430 with 50,000 miles.
Any suggestions appreciated.
Thanks.
- The strut is installed in the wrong orientation.
- The wire harnesses are not properly connected. This will cause error messages and very stiff suspension.
- The compressor is not mounted correctly. The mounts are somewhat complicated, with springs, rubber cushions and loose-fitting bolts. If the mounts are not installed correctly, you will get very noticeable noise and vibrations.
It is not a guess that the mechanic is NOT knowledgeable or experienced, and appears to be ethically challenged.
Arnott new-manufacture struts do not have the adjustable damper settings, but they perform well with factory struts set at medium stiffness.The electronics in these units is there only to prevent the computer from reporting a trouble code because the adjustable damper function is not there.
I have received a faulty Arnott rebuild, but it was replaced very quickly with minimum hassle and no cost. They shipped a replacement strut while I still had the faulty strut installed, so the car was out of service for only a couple of hours. I remain a satisfied Arnott customer, but have no business or financial link at all with them.
this is how the compressor needs to be installed. Parts 36-40.
BTW even you all like Arnott so well, MB recommends to replace Airmatic struts as a pair, after 50,000 mls, even only one failed. But the best choice and best performance you'll get using the original Bilstein struts. They never come defective and therefore no need to invest the time (and money) for a second try. Reconditioned air struts are a nonsence, as the worn parts cannot be replaced, being integral components of the strut, just check the pictures under www.w220.ee The only parts which can be replace d, are a few seals and O-rings....
* Indeed you CAN install an Arnott designed strut next to an OE strut. Most people don't notice unless they are constantly adjusting the damping - which in that case they should have gotten the Arnott Remanufactured OE part. As it turns out - most people "set it, and forget it" so the Arnott designed units work out well
* Inevitably a remanufactured W220 strut will have a higher failure rate than an OE or Arnott designed new strut:
I can understand why bamberger_1 is saying replace them in pairs. I tend to do so basically because almost every car I've worked on still has the factory MB-brand struts, and it comes down to age (one's going, the other's probably about to). I've seen them with one Arnott reman on one side and the factory one on the other, and the car drove just fine, until eventually the other side (the factory strut) needed replacement as well. So, you absolutely can do just one side if you wish, but if so, I'd recommend using Arnott's reman instead of the new-manufacture one due to the adjustable firmness (some people really do prefer Comfort or Sport 2 modes).
As for Arnott's reliability, all but one of our W220's (we have four) use Arnott remanufactured front AIRmatic struts. The only one that doesn't is the S600, which came with ABC. So far, we have experienced no problems with the struts themselves.
Now, that said, since Rock Auto isn't getting in any more brand-new Bilsteins (Rock Auto's prices were great), I would then consider the new-manufacture Arnott struts. They're basically set permanently in "Sport 1" mode, which I happen to prefer (so does the wife).
