Location rotary speed and lateral acceleration sensor S500
I bought this S500 cheap so of course it has issues. Just replaced both front wheel speed sensors. There were no sensors on the wheels?? Go figure..
I replaced the sensors over the issues of no ESP, no ABS, presafe not active, and cruise control not working. DTCs showed only the two sensors having fault. No other codes were present. After installing the sensors all warnings went away and cruise now works. That's nice but the ABS light remains on despite the fact that the ABS warning went away. I ran another scan under ESP and found no more wheel sensor codes but now a code for rotary speed and lateral acceleration sensor has a fault. This appeared after the sensors went on to the car.
I am asking 2 things. I want to know exactly where my sensor is located? I have looked for this info and find different locations from the trunk to inside the console and under the passenger seat. Seems that different models are different. My car is a 2004 w220 S500. Can someone that knows this car tell me where to look?
The second thing I am asking is if anyone can tell what they may know about this fault of ratary speed and lateral acceleration sensor? Is this why I still have the amber ABS light on?
thanks in advance for any advice, it will be appreciated. Bruce
Received 4,005 Likes
2017 GLE350 4MATIC
You need WIS and EPC. Google and the search button on this site will find it for you.
B24/15 is located under the left rear passenger seat cushion for model 220 with engines 112, 113, 137, 613 and 628 after June 2000. Per WIS GF42.45-P-4801-01C.
chassis (12-31-2019)
