One touch sunroof -problem? Help
I am struggling with the sunroof a bit myself. On the CL, this used to be a total no-brainer, but on the S-class the memory is surpringly stubborn.
The memory holds the last position of the sunroof. If not completely open, the next time you open it, it will stop at the same "semi-open" position. Normally all you do is press the open button again and hold the button (past the click in the switch) until the new desired or fully "open" position is reached. That's it.
Problem is on my S-class that doesn't seem to work consistently. I got it to have the memory setting further back, but not completely open.
Go figure!
Let me know how it works for you...
Wolfman
