PSE Pump?
Car: 2006 S500 Base. For the past several months. I noticed that my PSE pump makes clicking noise in the trunk for first 10-15 minutes when you drive the car. After this time, there is no more clicking (does it means no more leak??). Anyway, I am assuming that there is a small leak somewhere in the system but I need help to guide me to the right place. So far, my observation:
a) All 4 doors soft close operate normal
b) trunk soft close operates normal
c) Abnormal: I notice that both driver & front passenger lumbar supports do not hold pressure... they both slowly delated then inflated every once in a while driving. Since both sides did the same thing, i think both lumbar pouch are okay?
So the questions: Is my PSE on the way out and need replacement OR there is a leak somewhere that I don't know? For a replacement, what part # should I look for as 220 800 xx xx for 2006 cars? Sorry, I haven't open & look at my unit in the trunk yet so I don't know. Unless I missed it, I searched w220 forums and didn't see any members with my specific problem.
Thanks and appreciate any helps!
tnn
tnn
I know what you are talking but my car does not have the pulse massage option/feature. Both front seats just have a simple thumbwheel dial to set the lumbar support hardness. The PSE pump clicking/clunking noise is quite loud. I am sure that its abnormal.
Thanks.
If you mean that your trunk goes from fully open to fully closed quickly and powerfully, are you saying that you close the trunk lid by pushing the button on the bottom edge of the lid? If so, that closure has nothing to do with the "soft-close" operation. Soft-close moves the trunk lid only a fraction of an inch. Full closure is done by a hydraulic pump mounted behind the battery, not the PSE (Pneumatic Service Equipment) pump, which is mounted in the forward left corner, behind the trunk liner.
