Key Fob issue (won't open/lock/trunk) but still starts
I checked the battery/signal and it's fine.I also checked fuse 58 but it looks good.
I did the keyfob 3 different reset procedures but nothing. Here is what I tried so farProcedure #1
- Insert the key into the ignition.
- Quickly remove key from ignition and within 10 seconds hold down the lock button.
- Continue holding the lock button, and at the same time press, the unlock button five times.
- Next release all buttons and press the gate/trunk button one time.
- Your Mercedes remote should be synchronized. Test to see if lock / unlock functions are working.
Pos 1> hold lock 5 sec >hold unlock 5 sec >Hold both for 5 sec > repeat in Pos 2
Procedure #3
https://itstillruns.com/reset-mercedes-key-7492936.html
Procedure #4
https://itstillruns.com/reprogram-me...e-5014706.html
I tried above multiple times, still no luck.
Any ideas what else I can do?
Procedure #3
Procedure #4
Replace your key fob battery
Both key batteries are good
So it looks like it works when I point it at the handle (close).
Sounds like the Antena is not getting the signal?
buy a new siren box from the dealer , all used ones have an equally old battery
PS. I did also redid all of the steps to resync prior to pulling fuse (but much quicker, within 10 sec). But when I tested directly after, it wasn't working.
Seems like pulling the fuse did the trick? I also pulled 2 other fuses (# 1 and #2 from the right side of the rear seat fuse box). #61 is 5th.
Thanks to everyone for your help!
Possibly a failure of the LOCK solenoid valve in the PSE (Pneumatic Service Equipment) unit.
