Coilover Conversion W220 S600 with ABC
Specs were dual springs with 14k front and 10k rear and single dampening adjustments. The company was good to deal with and I specified my need for coilovers for an airmatic suspension since I was unsure if there was a difference. I did this to allow for the installation of swaybars from an airmatic suspension. I don't recall the specific wait time but I'm guessing 3-4 weeks to receive them at a cost of $1,140 I believe.
In the meantime I sourced the swaybars, endlinks and swaybar mounts from an S430 at a Pullapart local to me and lucked out there. Total with the AC compressor I needed for my failed compressor was $100. New lower control arms for an airmatic suspension were also purchased since I didn't want to risk worn bushings and opted for extra peace of mind.
Installing wasn't too difficult just time consuming. I did it all in my driveway over a weekend. 12 point 3/8 and 5/16 sockets fit perfectly on most of the reverse torx bolts. Remove the upper radiator hard pipe with hose and the electric fan to gain access to the tandem pump and make sure to protect the fan speed regulator from water . My cooling circuit hose drained into it with the electrical connector unplugged and required me to replace the fan and motor due to this oversight on my part.
Remove the ABC/PS resorvoir to provide more access to the tandem pump. The high pressure/discharge line on the bottom can be a PIA to loosen with pump still bolted up so I remove the bolts first to angle it better to get the box wrench in there. Basically this info can be found in a pump replacement thread. I believe this takes a 17mm wrench. Pump removal is necessary to modify it as I did or use spacers etc to install a regular PS pump. Some people recirculate the fluid through the cooler and back to the resorvoir but my 2nd pump was already damaged and whining. 1st pump was ruined when I bought the car by P/O who ran it dry and I installed this 2nd remanufactured pump which I chose to modify for my conversion. More on that later.
I supported the rear differential with my floor jack and removed the 4 subframe bolts, a 14mm socket I believe. Remove the bottom bolts for both of the rear struts and gently begin to lower the whole assembly as one piece. Be careful you don't stress the hoses for the brakes when you do this. When lowering pay attention to the level indicators and you may wish to disconnect them from the rear assembly to avoid any damage. It is possible they affect traction control so I made sure mine were not damaged during this step. I now removed the rear struts with the extra space to slide them out.
The rear sway bar is fed through once the rear is lowered and with the angles it may be frustrating but with some patience I fed it through even with the end links still attached. Once the bar is through you can install the coilovers and raise the subframe back into position. The mounting points are already there on the subframe along with the mounting points to the lower control arms.
I removed the pulley and began to remove the individual pistons found underneath the cover. Remember how I said it was "remanufactured"? The allen head plugs were already damaged from their assembly so 2 were were stuck, but easily bypassed by unbolting the front assembly with the long bolts holding the assembly together and I removed the pistons and springs this way. There is a write up on here I believe on rebuilding the tandem pump so refer to that for help, but it is fairly simple once you have it in hand. The shaft has an offset cam on it that rotates and moves the pistons up and down to build pressure, aka rotary piston pump. I also removed this cam from the shaft. There are 2 sleeve bearings that require lubrication with a feed hole. There was a small plug on the bottom side of the bearing area that I drilled out to allow lubrication all around. The shaft was already heated and scored slightly and the sleeve bearings showed wear/damage from just a short time of running dry when a hose burst. I chose to clean up the bearing surface with Emery cloth and polished the shaft surface to reuse it since it will no longer be a pump, only an extended shaft for the PS side of the pump and there have been absolutely no issues so far. When these pumps go bad it is because the sleeve bearings are not lubricated and the piston surfaces are also damaged. Once modified I had to make sure the large o-rings under the cover were in good condition and put it all back together. You may choose to put new o-rings and shaft seal in at this point for peace of mind and avoid any leaks, but again, I reused mine since it will no longer see any pressure. The bottom of the pump now has a hole where the discharge was at. A 16x1.5 threaded oil plug with seal will work here. My pump was reinstalled and I used 3/4" hose and a 90° elbow with a piece of clear tubing facing straight up. I now filled the pump with an oil bath for the bearings but keep in mind that the inlet is a very small path and the air has to be displaced from inside to add oil, so wiggle the tube to allow the air to escape. Eventually it will fill and the clear tubing allowed me to keep adding until it finally stopped taking oil. There is a vented bolt in the top of the clear tubing to allow the air to escape and keep trash out. I did consider using a tee and aftermarket PS resorvoir for both sides of the pump but wanted to try the cheap and easy clear tubing since I wasnt sure of the outcome modifying the pump as I did. Before the pump had a very slight whine, possibly a bad "remanufactured" rebuild, but there is absolutely no noise now so I am happy with this solution and don't expect any failure from it as long as the sleeve bearings are now in the "oil bath". They don't require pressure, only lubrication.
As mentioned I installed the swaybars and the tires will lose traction before I feel any body roll. There is no wallowing over dips and the car feels extremely "sure footed" for a 4600# sedan. Coilovers allow 30 clicks of adjustment and I have settled on 15-20 clicks towards the firmest setting and it is still extremely comfortable to ride in over the roughest sections of roads I travel. I did not adjust the preloaded spring settings and only the ride height. I have plenty of suspension travel even with it lower than factory and would have to launch it over the railroad tracks to bottom out.
I believe the ride quality is awesome and feels more controlled and I am more in touch with what the vehicle is doing when going through curves etc. Like I say, body roll is a non issue and I am a big fan of the Ceika coilovers. I cannot compare them to any other brands but I only have one regret and that is that I wasted money trying to keep the ABC functioning rather than just going straight to these coilovers and saving money in the long run.
I am an industrial mechanic by trade and don't mind working on any of my own vehicles and am pretty handy but I prefer driving them...haha. This car is once again a joy to drive and offers the package i was hoping for with my initial purchase of it.
My daytime photo will not upload for some reason so I'll take another over the weekend to show how the car sits, so here is this photo for now.
This is the plug that i drilled out to allow oil to pass through the sleeve bearing. There is also an open port already at the top. I have 2 pumps at my disposal so I plan to modify the other as well since the internals were in better condition. I figured if it did not function correctly at least I was only going to ruin the pump that was already damaged more severely.
I also used a burr bit to notch that area since originally this was sealed from the low pressure area.
This is a poor photo, but it shows the location of the other plug that i drilled out at the bottom of the inner sleeve bearing to allow an oil path all the way through. I believe originally the bearings are lubricated with low pressure oil and the plug is there to separate bearings from the higher pressure side of the pump. I wanted fresh oil to access both sides and not be stopped in one area.
I have a 2006 S65 AMG, with ABC, so I think this will be very close to the procedure for my conversion.
