Quick question
Old Aug 3, 2004 | 10:27 PM
naijaman's Avatar
2000 S430, 2002 Range Rover HSE 1985 BMW 535 (Sold), 99 BMW 530 (R.I.P), 98 Mazda Millenia (R.I.P)
Quick question
Hey guys....looking at my gearbox, I notice there is a button with a "W" and an "S". What is this button for?
Thanks in advance!!!
Old Aug 3, 2004 | 11:53 PM
dtxmob's Avatar
2000 S-Class
W=Winter Mode
S=Sport Mode
Old Aug 4, 2004 | 02:46 AM
Wolfman's Avatar
Super Moderator
Btw. The only difference is that the Winter mode starts in second gear instead of first.
Come to think of it, I never used that one, even in snow. Does anybody ever
Wolfman
Old Aug 4, 2004 | 08:45 AM
jahummer's Avatar
s430
I use W for day to day commute, seems to shift more smoothly and maybe has better fuel usage.
Old Aug 4, 2004 | 11:34 AM
sportlichE430's Avatar
Post
Jahummer,
Nobody in Tampa Bay should have to use the W setting
You won't get better mileage starting off in 2nd gear, this is to minimize spin/maximize traction in snow
ps: naijaman, read/get yourself an owners manual, try to be more specific with your thread titles....
Old Aug 4, 2004 | 04:39 PM
benzboy's Avatar
SL500 E320 ML350
W=winter S=summer
Old Aug 4, 2004 | 05:03 PM
dtxmob's Avatar
2000 S-Class
Originally Posted by benzboy
W=winter S=summer
YEAH THAT'S IT!!
Old Aug 4, 2004 | 08:35 PM
Wolfman's Avatar
Super Moderator
That's right. It actually does neither; Shifting patterns do not change and the fuel usage will be about the same.
Actually what you will get is the standard shift pattern of the previous S-Class which always started from 2nd gear (unless you went past the kick-down). This was much lamented and finally changed by MB.
Wolfman
Old Aug 4, 2004 | 10:11 PM
IluvS500's Avatar
Jeep Grand Cherokee Overland
W=winter S=summer
thank god u got it cuz i couldnt think of it but i knew it wasnt sport. Thats what the buttons on the dash are for lol
Old Aug 4, 2004 | 10:44 PM
Thericker's Avatar
V12-Biturbo
Dude you hit the nail on the head.....
Originally Posted by sportlichE430
Jahummer,
Old Aug 6, 2004 | 02:32 AM
S_kLaSse's Avatar
300E
Are you sure S is for "Summer". I thought it is "Standard". lol either way is fine, just use S for normal driving.
Old Jan 21, 2006 | 08:25 AM
e420benz's Avatar
97 e420 sport
car stuck in winter mode
my car is stuck in winter mode can you replace the switch, actually what do i do!
Old Jan 21, 2006 | 09:43 AM
ruykava's Avatar
Mercedes all the way!
e420benz: drive to the nearest dealer is the best i can think of! hopefully just a physical thing that should be easily corrected.
actually, for some reason i do find the shifting speed to be different between S and W mode. it seems to "slur" shifts more in W. the result is a bit more hesitation between changing gears. always find it more snappy in S. might be my imagination, but i don't think so :p
Old Jan 21, 2006 | 11:50 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Angry
If the switch is stuck, I have seen in a thread somewhere this switch is an integral part of the shifter box and you need to swap the electrical part of the shifter box too. EXPENSIVE :-(
Old Jan 21, 2006 | 08:26 PM
JAM's Avatar
JAM
SL600
S=Standard
W=Winter/Wet
In the W mode, in addition to starting in second gear, the car also uses a second reverse gear to minimize slip.
Also, upshifts happen at lower RPMs, again to minmize slipping--this probably explains why it feels like it is shifting smoother.
I use the W mode whenever it rains to keep my urge for out-of-the-gate acceleration under control.
Old Jan 22, 2006 | 01:41 AM
e420benz's Avatar
97 e420 sport
how do you replace it. Is it a DIY! what all do you replace
Old Jan 22, 2006 | 07:02 PM
newton22's Avatar
BMW E39
W=winter S=summer
What about spring and fall? :p
Old Jan 22, 2006 | 07:50 PM
winmaw's Avatar
2000 S500, 2001 Camry,1996 Honda SUV
Don't use and park in garage. he he
Old Jan 23, 2006 | 02:16 PM
wrb2's Avatar
2002 S600 Designo
For those of you who need owners manual.
Go to this site and register your car with Mercedes. After you have completed registration, you may download your owners manual. It is a .pdf file.
http://www.mbusa.com/index.do
