Trunk don’t close with soft close
I take fuse 20amp. Out in 5 minutes and put in again for the trunk. Then I open the trunk three times in a row, with no problem.
Then the fourth time it saids “click” and the chrome handle goes immediately in and the soft close do not go work. Then I have to manually push the trunk down in close position.
The only way to get the normal three times again is to take the fuse out and put in again.
Could anyone help me with this challenge?
Thank you very much.
Your situation indicates that it is very likely that either the pneumatic actuator on the trunk latch mechanism, or one of its feed lines, is leaking, so the soft-close operation is taking longer than programmed, and has been shut down. The suggested fix is to carefully check the actuator for cracks and leaks, along with its feed lines. Some folks have had good luck repairing the actuator with clamps or tie-wraps plus a high-quality epoxy. Other folks have preferred to replace the actuator, or the entire assembly.
There are quite a few YouTube videos and many write-ups on doing the repairs. Google "w220 trunk actuator repair" to start...
thank you very much.
Now my trunk works again and the dirt free handle goes in 6 seconds 💪🏻
I had 2 leaks, 1 big one in the back of the handle mechanism and one behind the actuator.
I use fast glue and glue to use to put front windows in car.
Thank you for your help.
I had an even more challenging issue, where the power line to the actuator is cut, which happened inside that braided loom on the right side of the trunk lid. The wires move up and down and eventually gets cut. Had to run a new line from the actuator down to the right side of the trunk and t-tap. Now works amazing. Took me a long time to figure it out.
