2003 S430
This is a very common problem on the W220. There is a small plastic safety lever inside the shifter that is solenoid-operated to hold the lever in PARK until the brake pedal is pressed. The two common failure modes are:
- The plastic lever breaks, and won't release the shift lever. Replacement is within the abilities of a reasonably good DIY owner. There are three different levers that have been used, with no way to tell which you have until you disassemble the shifter. You can buy a kit that includes all three for a reasonable price on line. Or, you can remove the safety lever, and the shift lever can be moved from PARK without pushing the brake pedal - just as was standard for many years. There are many write-ups and videos on this problem - Google is your friend.
- The brake light switch might have failed.
the car will be able to shift out of park At any time , even when the car is off , but if you have no children in the car and you are caReful this shouldn’t be an issue
