An outlier on Airmatic?
The S430 didn't satisfied my need for speed so I gave it to my son 4 years ago when he started college. For the last 4 years, this car wasn't garaged in desert heat in the summer and freezing cold in the winter. Today, it has 135k miles but surprisingly the airmatic still functions faultlessly. It might fail tomorrow, next week or next month but it haven't failed yet. Besides the Hella relay and the crumbled hose on the pump, I haven't done anything else on airmatic maintenance.
Is this an outlier? I don't know. With above conditions over 16yrs, I'm doubted if this is just an outlier. Often we read about early failures but we don't hear much from reliability stories so I thought I would share. Anyone else with original airmatic struts with over 150k miles?
For the sake of argument, my car spent most of its life in Southern California so it had a good early life. Now it lives in literal hell here in Houston, TX.
Good luck with your car!
There are clunky sounds when I drove over the bumps so I will need to replace the control arms [65]. While at it, I will probably replace the ball joint [10] and the spring control arms [40] also.
Only ball joint [10] might need special tool to press out/in. Everything else seems straight forward.
Anyway, with the mud guard off, the compressor air filter and grommet was exposed. Both were replaced in 2017 or 30k miles ago. Looks like this needs to be a regularly maintenance item for airmatic.
